Case glass cone with reflective white interior or transparent glass cone. Case glass Includes low-voltage, 50 watt halogen bi-pin lamp or 8 watt replaceable 500 lumen 80 CRI 3000K LED SORAA module. Transparent glass includes low-voltage, 50 watt MR16 flood lamp. Each include six feet of field-cuttable suspension cable. Product Features: Designed to cast light in a downward direction Manufacturer Warranty: 5 Year Includes (1) 6 watt Integrated LED bulb ETL Listed for use in dry locations Product Dimensions: Height: 6.5" (measured from ceiling to bottom most point of fixture) Width: 3.9" (measured from furthest point left to furthest point right on fixture) Depth: 3.9" Electrical Specifications: Bulb Base: Integrated LED Bulb Included: Yes Bulb Type: LED Watts Per Bulb: 6 Wattage: 6 Shade Specifications: Shade Color: Red Shade Material: Glass Shade Shape: Cone
Store | Price |
Build.com | [show price] |
If you do not have additional like this, now it is the best moment to buy one Tech Lighting 700MPCONR-LEDS830 Cone 1 Light LED Pendant with Glass. You will not regret!
